Throttle Body Removal and Cleaning [How-To with Pictures] - Dakota Durango Forum
Air Intakes & Throttle Bodies Parts Info Links : Air Intakes * Air Hats * Throttle Bodies
Thread Tools Rating: Thread Rating: 21 votes, 5.00 average. Display Modes
post #1 of 35 Old 01-15-2010, 05:53 AM Thread Starter
Leadfootluke
Vehicle: 1998 Dodge Dakota
I was looking for a comprehensive writeup before doing this and I did not see one, so I thought I would make one.
Parts list
- 8mm Socket for the Throttle Cable brackets
- 10mm Socket or necessary size for battery terminal disconnect
- 13mm Socket for the bolts that hold the Throttle body itself down.
- #25 Torx driver for the IAC, MAP, and TPS
- Adjustable wrench [in my case, for the airhat removal]
- CRC Throttle Body and Air Intake Cleaner [or similar cleaning product][/URL]
- Replacement gasket [good idea to have around, and about $2.50 from advanced auto or a similar place]
Procedures
1. Remove Negative Battery Connection. Tool: 10mm Socket if applicable
2. a) Locate Air Intake and Remove the Assembly.
2. b) Resulting Image.
3. a) Locate the IAC [Idle Air Control] and disconnect it
3. b) Locate the TPS [Throttle Position Sensor] and disconnect it
3. c) and Locate the MAP [Manifold Absolute Pressure] Sensor
3. d) Remove the Vacuum line as well
4. Disconnect the C-Clamps holding the throttle linkage. Note, the rear linkage goes to the Transmission [kickback] and the front two are for throttle and cruise control
4. a) From the furthest from the Throttle Body to the closest C-Clamp Connection.
4. b)
4. c)
Leadfootluke is offline
post #2 of 35 Old 01-15-2010, 05:55 AM Thread Starter
Leadfootluke
5. Remove the Throttle Bracket Tool: 8mm Socket
5. a) The one on the side of the bracket
5. a) The two on the front of the bracket
6. Remove the Throttle Body Bolts Tool: 13mm Socket
7. Remove the Throttle Body and the Gasket
8. Remove all 3 Sensors from the Throttle Body. The torx driver is used to remove all of the sensors Tool: #25 Torx Driver
9. Resulting [Dirty] Naked Throttle Body
post #3 of 35 Old 01-15-2010, 05:55 AM Thread Starter
Leadfootluke
10. Cleaning the Throttle Body. Tool: Intake Cleaner of choice
Read the instructions on the can of cleaner as some have VERY strong fumes and will remove paint and stain clothing. With all of the sensor removed, liberally spray the CRC cleaner onto the areas you wish to clean. The stream essentially stripped all of the carbon off of the Throttle Body. Using a tooth brush and terry cloth I was able to strip all of the carbon I wanted off. Take the IAC sensor as well and clean that up. With the carbon removed from it's plunger and the area were it sits, your idle will smooth out. These are the results I wished to achieve. I believe 100% clean is attainable. I worked for about 95% because I will probably port/polish my Throttle Body in the near future.
Let the Throttle Body dry before re-installation.
11. Re-installation:
Follow the steps in reverse order. Add the New gasket before replacing the Throttle Body. Reconnect the battery and start it up to make sure everything was done correctly.
Good luck and post up if you need assistance
post #4 of 35 Old 01-15-2010, 06:00 AM
KotaChuk678
Nice
KotaChuk678 is offline
post #5 of 35 Old 01-15-2010, 11:04 AM
bwdakrt
Posts: n/a
Quoted: Post(s)
Excellent job and write-up!
post #6 of 35 Old 01-15-2010, 03:18 PM
bludaker
bludaker's Avatar
Vehicle: 1999 dakota r/t rc
Great Info/Pics...
bludaker is offline
post #7 of 35 Old 01-15-2010, 04:27 PM
00Dingo
Pre-Teen Giggle Brigade
00Dingo's Avatar
Vehicle: 2000 Dodge Durango
good stuff
-Rod
RAKK SOLID..
00Dingo is offline
post #8 of 35 Old 01-15-2010, 04:42 PM
96BlkDak
Ugliest Truck on here!!!
96BlkDak's Avatar
Vehicle: 1996 Dakota CC V6 5Speed
Modifications: 1996 CC v6 5 SPEED
Send a message via MSN to 96BlkDak
great write up
Paul - no dakota currently, who thought finding a 91 318 5 speed CC would be so hard.
96BlkDak is offline
post #9 of 35 Old 01-15-2010, 06:45 PM
Jarheadoo7
don't feed the bears
Jarheadoo7's Avatar
Vehicle: 2001 Dakota
nice write up.. plenum looks like its holding too.. and check out the little spider folded up in the empty chamber
Jarheadoo7 is offline
post #10 of 35 Old 01-15-2010, 06:54 PM
rollers888
USMC
rollers888's Avatar
Vehicle: M16. Backed By Artillery.
thanks bro
rollers888 is offline
post #11 of 35 Old 01-15-2010, 07:33 PM Thread Starter
Leadfootluke
That was one on the outside of the nest. A whole bunch of those little red spiders were behind it. The CRC cleaner burned them all up
post #12 of 35 Old 01-16-2010, 04:16 AM
98Dak408
98Dak408's Avatar
Vehicle: 1998, CC Dakota R/T
Modifications: 408 N/A Stroker; Transgo; 4:56 Auburn; Hotchkis TVS; Sidewinder Customs Viper Brakes
Very thorough and clear write-up with pics. Good job! And I see you're from Michigan.
1998 Dakota R/T CC; 408 Stroker; Comp 220/230, SCT; Ported Eddy’s; M1; HiPoTek 53.6 mm TB; MP Headers; Single 3 1/2" Exhaust; Transgo; PATC 2800; Motive 4.56; Auburn LSD; Hotchkis TVS - 2/3 Drop; Sidewinder Customs 13" Viper Brakes; HiPoTek X-Brace, Driveshaft Loops, Engine Torque Strap, and Differential Cover.
Thank you for looking, Richard
98Dak408 is offline
post #13 of 35 Old 01-18-2010, 03:30 PM
ryangtp89
Vehicle: '98 dodge durango v8 mag
excellent write up! Verry informative and the pics came out great ++++ for you leadfootluke. I'm gonna save this for whenever i get a ported tb.
ryangtp89 is offline
post #14 of 35 Old 01-18-2010, 07:36 PM
2YuNg2Di
5.2-Toned SLT
2YuNg2Di's Avatar
Vehicle: 1999 Dakota SLT CC 5.2L
Very nice. Thanks
'99 Dakota SLT 5.2L- -Edelbrock Breather- -Edelbrock Ceramic Shories- -Spintech ProStreet- -MagnaFlow Cat.- -Cragar 441's- -BFG Radial T/A's- -Pioneer Head Unit- -Hypertech- -Mopar Tonneau- -Crystal Headlights & Corners- -Smoked Tails-
2YuNg2Di is offline
post #15 of 35 Old 01-21-2010, 04:27 AM
Reject
Vehicle: 05 Dodge Dakota CC V6
Wat is the best tool to use to get the TB itself off, I tried a Ratchet, and impact gun, neither worked. Also had the same problem trying to get the front bumper off.
Reject is offline
