P203,P201,P205, now P202 - Dakota Durango Forum
post #1 of 9 Old 01-08-2010, 12:16 AM Thread Starter
ShawnTRD
Vehicle: 2000 Dodge Dakota 4.7L
Hi guys, I trying to help my friend figure this out. His CEL has been on for some time now. He sometimes even has a lose in power. He has code P0203, and another time he had P203,P201, and P205. So he thought it was his injectors on that side. I guess there the first three on the fuel rail. So he just replaced #1, #3, and #5 Injectors on Tuesday. Now he got the CEL again today and it's P0202 (Injector #2). Last year he replaced the Y-Pipe/ Cat System, and all O2 Sensors. Then last Spring he replaced the Throttle Position Sensor. So what could be causing this now?
2000 Dakota 4.7" Automatic
Thanks
Shawn
ShawnTRD is offline
post #2 of 9 Old 01-08-2010, 12:35 AM
Ranger50
Just a poor shlep......
Vehicle: 95 Dakota Sport 3.9/2wd
You either have a bad connections back to the PCM, a bad PCM, or a corroded ASD relay power feed to the injectors. Happy hunting down the electrical gremlin.
Brian
95 Dakota Sport
"Never trust an intelligent man with no money to play fair."
Ranger50 is offline
post #3 of 9 Old 01-08-2010, 12:44 AM Thread Starter
ShawnTRD
Thanks, but can you give me some more info on PCM? I do I PCM search and I'm finding a lot of random stuff. Picture? Cost? Any testing he can do?
ShawnTRD is offline
post #4 of 9 Old 01-08-2010, 01:55 AM Thread Starter
ShawnTRD
Ok I guess the PCM is the Engine Computer ECU, ECM.. Where is it at? I'll have him try unplugging it and plugging it back in. It he still has the problem, and the dealer tell him if it's bad?
ShawnTRD is offline
post #5 of 9 Old 02-04-2010, 04:54 PM
biggradak
Vehicle: 2002 Dakota 4x4
hey man. havin the same problem only its ijs. 1 - 6. also gettin a misfire on cyls 6 and 8. did your friend ever figure it out? what is the asd relay?
biggradak is offline
post #6 of 9 Old 02-04-2010, 05:47 PM Thread Starter
ShawnTRD
Haven't figured it out yet.
ShawnTRD is offline
post #7 of 9 Old 02-04-2010, 05:50 PM
biggradak
any adea what the asd relay is or where its at?
post #8 of 9 Old 12-27-2012, 10:27 PM
jmfischer
Vehicle: 99 dakota sport
Hi Guys, on another forum thread which you can get to if you type in Po201 & po202 fuel injector malifunction there is some good advice there. It turns out that some have solved the problem replacing a TPS sensor or even a Cam position sensor & a crank sensor.
jmfischer is offline
post #9 of 9 Old 01-01-2013, 01:11 AM
petrock
The Anti-RUB
petrock's Avatar
Vehicle: 4.7L '03 Durango SLT
Quoted: 16 Post(s)
http://www.obd-codes.com/p0201
http://www.obd-codes.com/p0202
http://www.obd-codes.com/p0203
http://www.obd-codes.com/p0205
jmfischer, I’m not sure how a sensor would effect the voltage reading on the fuel injectors circuit. They don't share power or ground or any other wires with the injectors in questions according to my '03 D's factory service manuals wiring diagrams.
See my write up on how to test the fuel injector circuits wiring: http://www.dakota-durango.com/forum/...40&postcount=3
K&N FIPK
YouTube Channel: Pet Rock’s Garage
petrock is offline
