4WD Problems W/ NV233 Transfer Case (Grinding) - Dakota Durango Forum
post #1 of 22 Old 12-30-2009, 10:58 PM Thread Starter
Tydog07
150,XXX Miles
Tydog07's Avatar
Vehicle: '02 Dur 4.7L SLT
Modifications: Dwight TB
I have the NV233 Transfer case that has the option between 2WD, 4 HI, 4LO and N. When I switch it from 2WD to 4WD HI, it makes an almost grinding type sound (I can hear something make like turns/revolutions, I almost want to say the drive shaft?)that you can hear when you step on the accelerator pedal. It doesn't make the noise when you coast or brake. I have tried switching it both when stopped in the park gear and in the drive gear. I have also tried switching it going about 25 mph. I can tell it's working, because of the added traction in the snow, but it still makes that noise. I don't seem to have the 4WD service light on, is there a fluid level I can check? Any help would be nice, I can survive without it because of my decent all season tires (General Grabber HTS), but incase I ever do need it, I would like to have it working. Thanks in advance!
5DW #187 A lot of stuff...
Tydog07 is offline
post #2 of 22 Old 12-31-2009, 12:45 AM
99Dakota
Diesel Mechanic
99Dakota's Avatar
Vehicle: 99 Dakota 4x4
how many miles are on it? and has the driveline ever been serviced? if not its definetly due. you can check the level on the tcase by removing the fill plug and seeing if the fluid is level with the hole.
99 Dakota Sport 4x4 3.9L V6
360 Air Intakez, V8 TB, MSD Coil, Magnaflow Y-Pipe back, Superchips 3715, Factory 3.92's, Firestone Destination A/T's, HID 5000K BI, HID 6000k Fogs, Monroe Sensatrac Rear Loadlevelers
99Dakota is offline
post #3 of 22 Old 12-31-2009, 03:50 AM
caulk04
Vehicle: none
Drain the fluid and check it for debris. 10mm hex to remove the drain and fill plugs.
Takes a couple quarts of ATF+4.
caulk04 is offline
post #4 of 22 Old 12-31-2009, 04:07 AM Thread Starter
Tydog07
150,XXX Miles
Tydog07's Avatar
I have 132,000 miles on her, whats the driveline and how much will that cost? Wheres the fill plug to tell if I'm low on fluid?
Tydog07 is offline
post #5 of 22 Old 12-31-2009, 04:17 AM
trevor
Vehicle: Null
The 'driveline' is your Engine, Tranny, transfer case, driveshafts, diffs, etc... Its a 'system' on your truck.
There are 2 plugs on the back of the transfer case. One at the bottom, facing rearward, and one maybe 6" higher up. The bottom one is the drain plug, the top one is the fill. Pull both the plugs and check the magnet on the drain plug (I think there is a magnet on it, I could be wrong) and check the oil that comes out. If there's metal shavings in it, you have pretty serious problems, and it needs to be professionally looked at.
When you put the plugs back in, remember to use a thread sealant.
A good sharp edge is a man's best hedge against the vague uncertainties of life.
trevor is offline
post #6 of 22 Old 12-31-2009, 01:39 PM Thread Starter
Tydog07
150,XXX Miles
Tydog07's Avatar
I know I'm going to sound really stupid but where do I find the transfer case? Is it under the hood or under the car itself? And would I be looking for the metal on the magnet or the metal coming out in the oil itself?
Tydog07 is offline
post #7 of 22 Old 12-31-2009, 03:55 PM
trevor
Vehicle: Null
The transfer case is right behind your transmission. Basically right under your seat, in the middle of the truck. If you walk up to your truck as though you were going to open the drivers door, crouch down and look underneath. You'll see the rear drive shaft run to the rear of the transfer case, and the front drive shaft will run to the front of the transfer case, on the drivers side.
You should be looking for metal in both. A little bit of VERY fine metal on the magnet is ok. It should be so fine that you won't even think its metal, just thick fluid stuck to the plug. You should not be able to see metal in the oil at all.
trevor is offline
post #8 of 22 Old 12-31-2009, 05:55 PM Thread Starter
Tydog07
150,XXX Miles
Tydog07's Avatar
Excellent, I'll have to give that a look.
Tydog07 is offline
post #9 of 22 Old 01-15-2010, 10:02 PM Thread Starter
Tydog07
150,XXX Miles
Tydog07's Avatar
Is ATF red? I am noticing a small leak in my driveway and it could be possibly from that.
Tydog07 is offline
post #10 of 22 Old 01-12-2011, 05:34 PM
x2nervisx
Vehicle: 2001 Dodge Durango
Yes ATF is red. I'm having the same problems with 4wd. I also have a grinding/clanking noise only when in 4wd and no noise at all in 2wd. Grinding noise happens when going straight and even little throttle applied. So far my research hss found that it could be a bad front driveshaft but I'm still looking for answers.
x2nervisx is offline
post #11 of 22 Old 01-12-2011, 09:16 PM Thread Starter
Tydog07
150,XXX Miles
Tydog07's Avatar
It's a bad front drive shaft (propeller shaft), the stock flange/yoke is bad and it needs to be replaced/refurbished (what i did $180). One of the two flanges will have a bunch or dirt and rust when you take it off (which is what you hear). I took my off and had it serviced, popped it back on (9 bolts) and it was/is good to go!
Tydog07 is offline
post #12 of 22 Old 01-12-2011, 09:47 PM
x2nervisx
Before you replaced your front driveshaft, was there any play when you tried to wiggle it or was it pretty tight? My front driveshaft doesn't really have any play on it but I guess I'll try replacing it anyway. Thanks for the update!
post #13 of 22 Old 01-26-2011, 10:10 PM
airgrumpy
Vehicle: 02 Dakota 4WD 4.7V8
HOLY COW! this is the same exact problem I have now. Griding when going in 4x4 forward and reverse. much worse in reverse. the stock flange/yoke you speak of....that is on the front drive shaft connected to the transfer case right? Oh FYI, I have a 2002 dakota sport 4x4, 4.7 v8 5 speed manual. Also replaced the pinion bearing and races and carrier bearing and races as well. They were really bad.
airgrumpy is offline
post #14 of 22 Old 01-26-2011, 10:27 PM
airgrumpy
Tydog07, Was it difficult to repair?
post #15 of 22 Old 01-27-2011, 01:28 AM
caulk04
Vehicle: none
Driveshaft replacement is easy. Four bolts at the front axle, 6 at the t-case. Done.
caulk04 is offline
