Shift Indicator Lags - Dakota Durango Forum
post #1 of 7 Old 12-21-2009, 09:14 PM Thread Starter
moparfreak83
Vehicle: 1998 Dodge Durango - 5.9L
Hi,
I've got a '98 Durango w/ 5.9L that's starting to exhibit some transmission headaches. A problem that I've had for awhile now, is that when I shift into D, N, R, etc., the red indicator is slow to actually move across to the right selection, leading to sometimes actually ending up in the wrong gear/drive selection. I'm pretty used to it, so it doesn't bother me too much, but when my wife or someone else gets in they have issues. The indicator also never reaches the right selection even when it catches up, the truck will be show being in Neutral when it's actually in Drive and on down the line.
I bought this truck from my Dad, and if I recall, he had this issue crop up 7-8 years ago, and the dealership took care of it during one of its maintenance visits. Since I do all my maintenance myself, I need to figure out what they did. Some sort of shift linkage adjustment?
Any ideas?
Thanks,
Adam
moparfreak83 is offline
post #2 of 7 Old 12-21-2009, 09:20 PM
hskrRT
nstg8tr
hskrRT's Avatar
Vehicle: 2000 R/T
Modifications: Lots 'O stuff
Quoted: 189 Post(s)
There is an adjuster wheel on the cable the moves the gear indicator
hskrRT is offline
post #3 of 7 Old 12-21-2009, 09:34 PM Thread Starter
moparfreak83
Brian,
Is the adjustment wheel down by the transmission or up towards the dash? I haven't gotten myself a factor manual yet.
Thanks,
Adam
post #4 of 7 Old 12-21-2009, 09:37 PM
hskrRT
nstg8tr
hskrRT's Avatar
Vehicle: 2000 R/T
Quoted: 189 Post(s)
It's unde the dash on the steering column,.
hskrRT is offline
post #5 of 7 Old 12-21-2009, 09:38 PM
Rebel13
Mods Addict
Vehicle: 2K R/T
That adjuster is a 2000 only I believe or pre-00. It is below the dash bezel, a little white plastic wheel that turns. You have to remove the panel above your right knee to see it if you have it.
Rebel13 is offline
post #6 of 7 Old 12-21-2009, 10:02 PM Thread Starter
moparfreak83
Excellent. You guys are very helpful. This problem has lingered so long, that I'm suspicious of such an easy fix, but I'm going to give it a shot and see if I have that adjustment wheel.
Thanks!
Adam
post #7 of 7 Old 12-21-2009, 11:11 PM
caulk04
Vehicle: none
It was used on all pre-00 trucks and on 00 trucks with the 3.9 and 5.9. ALL of the 01+ used the electronic gear display.
As mentioned, there is an adjuster, but it sounds like your cable is gummed up as well. If it doesn't respond immediately to movement of the shifter, something is dragging. May be something loose, may be a sticky cable. I'd see about getting a little PB Blaster or other light penetrating oil down the cable sleeve on both ends.
caulk04 is offline
