2001 to 2003 intake manifold swap - Dakota Durango Forum
post #1 of 52 Old 11-24-2009, 06:51 AM Thread Starter
Kosgey
Kosgey's Avatar
Vehicle: 2001 Dakota Sport CC 4.7L
Send a message via AIM to Kosgey Send a message via MSN to Kosgey Send a message via Yahoo to Kosgey
I recently found a great deal on a 2003 intake manifold and matching TB. Just curious if anyone has gone through with this swap and if they ran into any problems or if they had any suggestions on what to look out for.
Mods: Clear corners, homebrew intake, clutch fan removal, poor man's kill switch, 2003 intake manifold, Dwight TB
2001 Dakota 4.7
1995 Honda Nighthawk 750
Kosgey is offline
post #2 of 52 Old 11-24-2009, 07:23 AM
SLT kota
SLT kota's Avatar
Vehicle: 01 5 speed 4.7 RC Dakota SLT
Modifications: Boats, cars, racing, sailing, etc...
I haven't done that exact swap but I've been much further into it with the supercharger/manifold. It really isn't to bad but just will take you a while your first time. I'd plan a good part of a day if your doing it for the first time but realistically it can be done much faster (the first time with anything always seems to take 3 times a long)
The thing that sucks the most is that you are probably going to have to pull the heater lines, this really isn't a big problem but you will end up getting coolant everywhere (and I personally don't like it, especially cause I always have to end up laying in it after spilling it all over the garage lol)
I would drain as much coolant from the radiator as possible but you will still end up having it spill when you pull the heater lines. Not a big deal, just be prepared for it with something to clean it up.
If you aren't afraid to get dirty, you won't have any problems at all. Just some time with a deep 10MM and a few of his friends.
-Stuart-
- 2001 Kenne Bell 4.7L 5-Speed RC
- dog # 10 first dak dog!
www.AIRRAM.com Discounted Performance Parts with FREE SHIPPING!
SLT kota is offline
post #3 of 52 Old 11-24-2009, 07:47 AM Thread Starter
Kosgey
Kosgey's Avatar
Thanks for the heads up SLT kota!
2001 Dakota 4.7
Kosgey is offline
post #4 of 52 Old 11-24-2009, 10:32 AM
AIR_RAM
www.AIRRAM.com
AIR_RAM's Avatar
Vehicle: 2002 QC RAM 4.7L *SOLD*
Modifications: 2011 Grand Sport Corvette :)
Quoted: 6 Post(s)
What heater lines will he need to move? I dont recall any heater lines in the way... perhaps its a Dakota thing but I have never heard of it till today.
From what I remember you will need to move the fuel rail with injectors... Just screws each side and then just swing the fuel rail over to the drivers side... I would not even bother disconnecting the fuel line. Then just swap the intake out. And put the fuel rail/injectors back in place. Its only a 20-30min job tops.
I have been known to over simplify things though... But I have had mind off a good 15-20 times and I have also installed a few for customers.
You will absolutely LOVE that 03 intake over your 2001 Intake.
SPEED SAFE, AIR RAM
AIR_RAM is offline
post #5 of 52 Old 11-25-2009, 01:06 AM
moparsz
1700 + 1/4 mile passes
moparsz's Avatar
Vehicle: 2002 Dakota 4.7
Modifications: if you can think it, it probably has it
Quoted: 21 Post(s)
Garage
the dakotas have a heater hoses run just infront of the TB and you may not need to take them off. When I did mine I was able to pull them out of the way, but it bearly clears it. removing them would make it a lot easier. the hardest part about doing the swap is removing all the stuff thats on top of the intake it self. I've done the swap twice now (stock 2002 to a 2003 to a 2008)and I noticed an improvement each time
Best pass 2002 Dodge Dakota : 13.302 @ 103.39 MPH and 1/8 E.T. 8.569 @ 82.87mph
Drag Track http://www.youtube.com/watch?v=LCNQhtcXkKE
New Years Eve Burnout http://youtu.be/tnWhrInUB6o
moparsz is offline
post #6 of 52 Old 11-25-2009, 01:19 AM Thread Starter
Kosgey
Kosgey's Avatar
Thanks for the help guys - I might get to it this weekend but otherwise It'll be over Christmas break.
2001 Dakota 4.7
Kosgey is offline
post #7 of 52 Old 11-25-2009, 01:19 AM
SLT kota
SLT kota's Avatar
Ah, well if you don't have to remove the heater lines it would be much less of a pain, I had to remove and reroute mine which was lots of fun.
Depending on how much experience you have it could probably be done in 20-30 minutes. I would still allow a few hours the first time. If you do have to remove the fuel rail, it is just held on by 4 bolts (8MM), then just pull it up.
-Stuart-
SLT kota is offline
post #8 of 52 Old 11-25-2009, 07:46 AM Thread Starter
Kosgey
Kosgey's Avatar
Alright hopefully this won't be too big of a deal. Thanks for all the input guys.
2001 Dakota 4.7
Kosgey is offline
post #9 of 52 Old 11-25-2009, 08:51 AM
SLT kota
SLT kota's Avatar
It really isn't that bad at all, if you don't have to unhook the heater hose lines then will be easy, I would just plan for a few hours as things always seem to take longer then I plan.
-Stuart-
SLT kota is offline
post #10 of 52 Old 11-29-2009, 08:11 AM Thread Starter
Kosgey
Kosgey's Avatar
Well I got the new intake on and a couple things I discovered:
The tubing on the back of my '01 intake was off to the passenger and the '03 is in the middle. Well this distance ends up screwing you on the front side where it comes about an inch short of hooking up. Also the hookup on the back of the intake is different requiring a new coupler.
The sensor on the front of the '03 intake does NOT match up with the wiring from the '01.
2001 Dakota 4.7
Kosgey is offline
post #11 of 52 Old 11-29-2009, 08:28 AM
AIR_RAM
www.AIRRAM.com
AIR_RAM's Avatar
Quoted: 6 Post(s)
Are you talking about the MAP sensor? You should be able to reuse your 01 map sensor on the new intake... this way it will plug up.
PM me with any issues you are having... If anything they SHOULD be minimal and fixable with a quick trip to Autozone. But if your having any issues let me know so we can help you get them worked out.
Or just post them here... there are plenty of people here who have done the swap and can offer you good advice.
Im assuming the "TUBING" is just the PCV hose... And the "Wiring" is the MAP sensor... let us know....
SPEED SAFE, AIR RAM
AIR_RAM is offline
post #12 of 52 Old 11-29-2009, 08:39 AM Thread Starter
Kosgey
Kosgey's Avatar
Bear with me - I don't know what all the hookups are
Yes I pulled the MAP sensor from my '01 intake and put it on the '03 intake. EDIT: Had to clip off part of the plastic because the MAP sensor and the one below it bumped into each other.
As for the PCV hose, I hope it didn't get pinched in the back. What runs through there?
EDIT: There's a band of 3 plugs near the right of the TB; 2 go into the TB and the other one went into my 2001 intake...well there is no port on the 2003 intake for it. Just leave it or what?
2001 Dakota 4.7
Kosgey is offline
post #13 of 52 Old 12-01-2009, 05:10 AM
moparsz
moparsz's Avatar
Quoted: 21 Post(s)
Garage
Originally Posted by Kosgey View Post
As for the PCV hose, I hope it didn't get pinched in the back. What runs through there??
behind the intake is nothing except the firewall.
if its what I'm thinking of, 2 go into the TB and the 3rd should plug into the intake itself behind the TB.
moparsz is offline
post #14 of 52 Old 12-01-2009, 05:21 AM Thread Starter
Kosgey
Kosgey's Avatar
I know - I'm just concerned the hose got pinched against the firewall because it came straight off the back off the new manifold.
The 3rd plug WAS on the '01 manifold but I don't see a plug on the '03 - I'm sure this is the cause of my check engine light too.
2001 Dakota 4.7
Kosgey is offline
post #15 of 52 Old 12-01-2009, 05:23 AM
moparsz
moparsz's Avatar
Quoted: 21 Post(s)
Garage
There should be enough room behind it that its not pinched. I wish I still had my 03 intake so I could look exactly where mine hooked into it, but I sold it months ago
moparsz is offline
