wheel bearing maybe?? - Dakota Durango Forum
post #1 of 16 Old 11-15-2009, 05:59 AM Thread Starter
02sxtkota
No habla jibber jabber
02sxtkota's Avatar
Vehicle: 2002 dodge dakota sxt
Modifications: Bone stock except exhaust
Send a message via AIM to 02sxtkota
Weird noise coming from left side of truck and whenever i turn left, but it goes away if i move the wheel even the slightest to the right or turn right. Could it be a wheel bearing or what else could it be.
02sxtkota is offline
post #2 of 16 Old 11-15-2009, 07:37 AM
99fabtechdrango
i hate stupid old people
99fabtechdrango's Avatar
Vehicle: 1999 Durango SLT+ 5.2
Modifications: 3" fabtech lift, 31x10.50 BFG A/T's,15" eagle alloys, CAI, Flowmaster catback, poweraid tb spacer, msd coil and 8.5mm wires, dvd player and 2 7" headrest screens
definately take a look at the wheel bearings. jack it up so the wheel is off the ground and grab the tire by the sides. wiggle it back and forth. you'll feel if there is any slop in the bearing. you could have someone else move it and watch the bearings too. either way do not hesitate to check them out
5 DOOR WHORE #95
Originally Posted by cooter View Post
How about this, everytime you see the word fuck, think it means rainbows, because your gay.
99fabtechdrango is offline
post #3 of 16 Old 11-15-2009, 07:01 PM
caulk04
Vehicle: none
Sounds like a wheel bearing to me...
caulk04 is offline
post #4 of 16 Old 11-15-2009, 11:52 PM
Jarheadoo7
don't feed the bears
Jarheadoo7's Avatar
Vehicle: 2001 Dakota
ber
Jarheadoo7 is offline
post #5 of 16 Old 11-16-2009, 12:07 AM
Axiom
Juice Junky
Axiom's Avatar
Vehicle: 2001 Dodge Dakota 5.9 R/T
Check the dust shield behind the brake rotor. I had your exact same symptoms and I thought wheel bearing as well. Just ended up being that the dust shield was bent and would make contact with the rotor.
- Mark
Motor's shot. R.I.P. 8/17/09. Stroker in the works!
Axiom is offline
post #6 of 16 Old 11-16-2009, 03:59 AM Thread Starter
02sxtkota
02sxtkota's Avatar
awesome thanks guys ill check it out tomorrow, if wheel bearing ill replace right away and hoping its dust shield. Im guessing would be the left wwheel bearing then.
post #7 of 16 Old 11-16-2009, 04:11 AM
99Dakota
Diesel Mechanic
99Dakota's Avatar
Vehicle: 99 Dakota 4x4
a left wheel bearing would quiet while steering left.
99 Dakota Sport 4x4 3.9L V6
360 Air Intakez, V8 TB, MSD Coil, Magnaflow Y-Pipe back, Superchips 3715, Factory 3.92's, Firestone Destination A/T's, HID 5000K BI, HID 6000k Fogs, Monroe Sensatrac Rear Loadlevelers
99Dakota is offline
post #8 of 16 Old 11-16-2009, 04:23 AM Thread Starter
02sxtkota
02sxtkota's Avatar
thanks, knowing me i woulda just checked left, so ill check right first then might as well check left while at it.
post #9 of 16 Old 11-17-2009, 05:12 PM
ThisOldDak
Vehicle: 2010 Nitro SXT
Some oddities I have experienced on vehicles are..
- Brake pads low enough to very slightly touch the squealer when turning lightly to the left but not under breaking.
- Wheel bearing (I'm assuming) didn't like the wobbling motion of a tire with a broken belt. Once the tire was replaced the grinding noise went from every time I turn to only once in a while in a hard turn.
Either your truck's got balls or it doesn't. No fake plastic scrotum necessary.
Now dakotaless
ThisOldDak is offline
post #10 of 16 Old 11-17-2009, 05:56 PM
Bos-R/T
Bos-R/T's Avatar
Vehicle: 2001 Black CC R/T
Modifications: AEM CAI,SCT by hemifever,Gibson headers,High flow magnaflow converters,Magnaflow xpipe and mufflers,underdrive crank pulley,M1 intake,52x55mm F&B TB,Mega viper stage 3 tranny from PATC,Martin Saine VB
Actually grab the top and bottom of the tire and see if it wobbles.Left and right wobbling will check for worn out steering parts.
That can happen to but mostly if you have had the wheel off and bent it or did a brake job on it and bent it too.
This is so correct.All the weight is shifted to the other side.
Bos-R/T is offline
post #11 of 16 Old 11-17-2009, 06:48 PM
dkjones96
Vehicle: 1999 Durango 5.9 4x4
Not entirely correct. It depends on what is causing the sound. If it is grinding from a bad bearing or no lubrication that's true but if it is just a loose bearing it will get worse on the left when making a left turn because the lack of weight on that side lets the bearing slap around.
- Kyle
dkjones96 is offline
post #12 of 16 Old 11-17-2009, 07:14 PM
9t9-5.2
Home School Valedictorian
9t9-5.2's Avatar
Vehicle: 9t9-5.2
When the right front bearing on my Dak was going bad, it made a rumble/slight vibration when turning right. Most noticeable when taking a long sweeping on-ramp at 65
No fear, no doubt, all in balls out
If every American cared enough to purchase one USA made garment per year the impact would be $9 billion. That is a lot of American jobs.
9t9-5.2 is offline
post #13 of 16 Old 11-17-2009, 11:23 PM
Bos-R/T
Bos-R/T's Avatar
In my 12 years of owning my own shop I have never heard a wheel bearing slap around.Maybe the tire would start shaking like it was unbalanced but have never heard a wheel bearing slap around.Normally even if your turning in the opposite direction theres still too much weight for a bearing to slap around unless you have hydraulics and hittin three wheel and the bad bearing being the one in the air.Now I have heard one that was so loose make a knocking sound but only with the vehicle going straight with no tension on it at all.
Bos-R/T is offline
post #14 of 16 Old 11-18-2009, 03:12 AM Thread Starter
02sxtkota
02sxtkota's Avatar
so if only when i go left which one is it then?
post #15 of 16 Old 11-18-2009, 03:20 AM
Bos-R/T
Bos-R/T's Avatar
Just do this because someone can tell you the right way and the wrong way of how something sounds by turning right or left.Jack up your truck to where both front tires are off the ground.Go to either side and grab the bottom and top of the tire and see if it will wiggle.If its a noisy growling bearing you can put one hand on the upper control arm and spin the tire with the other and if you can feel any kind of roughness with your other hand on the control arm then its that bearing.If it wiggles then you will need to try to look at your ball joints and control arm and make sure they are not moving while you are wiggling.You may can look through your wheel and if the rotor is moving while you are wiggling but the dust shield is stationary then the wheel bearing is bad.
Bos-R/T is offline
