oil cap - Dakota Durango Forum
post #1 of 4 Old 04-20-2017, 06:54 AM Thread Starter
camdawg93
camdawg93's Avatar
oil cap
hi i have a 2000 dakota 3.9 liter and i have been working on and bought it from a buddy of mine when he had it he had no problems with the thing now that i have it i have alot of problems with it mind you this thing has been sitting sense last oct. getting started here and there to go around the block or just to move it but lately the oil cap is stuck on the valve covers and i cant get it off at all whats a good way to get it off without breaking it so far ive only tried wd40 and a pair of chanel locks on it
camdawg93 is offline
post #2 of 4 Old 04-20-2017, 11:32 AM
RalphP
RalphP's Avatar
Vehicle: 1988 Dodge Dakota SE
Quoted: 106 Post(s)
Are you trying to pull it off, or twist it off anti-clockwise?
Try twisting it.
If, however, it Just Will Not Come Loose, then break it, use your pliers to walk the lock piece out, and replace it with a new one. Here is one possible source for a replacement cap
http://www.rockauto.com/en/catalog/d...iller+cap,5269
RwP
RalphP is offline
post #3 of 4 Old 04-20-2017, 12:01 PM Thread Starter
camdawg93
camdawg93's Avatar
I am trying to twist off and when I get to to turn it just clicks both directions just clicks and I don't really wanna have to go out and buy a new one if I can avoid it ya know and how do I even break the thing off? Is there anyway around not breaking it ofd
post #4 of 4 Old 04-20-2017, 05:33 PM
RalphP
RalphP's Avatar
Quoted: 106 Post(s)
How much is your time worth?
New ones from RockAuto are under $5 (one at $3.24) before shipping ...
At that rate, I'd break off the top and use the pliers to twist the bottom out, since it seems like the overriding clutch is broken on your current cap.
To not break it off - remove the valve cover and unthread it from the inside. *dry* You may notice that the valve cover gasket set is pricer than the cap is ... and if it's doing what you're describing, the cap is broken, and will need to be replaced ANYWAY.
RwP
RalphP is offline
