Chrysler 8.25" Nitro Xtreme Aluminum, Increased-Capacity, Diff Cover - Dakota Durango Forum
post #1 of 13 Old 12-28-2014, 06:23 AM Thread Starter
justdiff
Differential Experts
justdiff's Avatar
Vehicle: Dodge Rear End Parts
Modifications: Nitro Gears, Auburn Posi's, HD Diff Covers, Solid Spacers
  • Reinforced aluminum protects better than OEM tin covers.
  • Aluminum material helps dissipates heat.
  • Increased oil capacity.
  • Fill and Drain plug for easy maintenance.
  • Recessed bolts.
  • Rust-proof metal.
  • Wide selection.
  • Made in USA.
Nitro Aluminum differential covers are extremely thick and have been thoroughly tested in Moab, King of Hammers, and numerous other locations, proving they will handle the rocks, roots, stumps, and anything else you can throw at them. Finned aluminum dissipates heat faster than steel reducing the operating temperature inside your differential and extending the life of your components. Recessed bolts completely eliminate the potential for bolt sheering when crawling over rough terrain. Aluminum can't rust and a Nitro aluminum differential cover will keep your undercarriage looking great all year round. Our wide selection of available covers makes it possible to equip both the front and rear differentials with Nitro covers on many vehicles.
  • Differential: CHY 8.25"
  • Material: Aluminum
  • Differential Bolts: 10 included
  • Manufacturer: Nitro Gear & Axle
  • Warranty: 1 year*
justdiff is offline
post #2 of 13 Old 02-16-2015, 09:06 PM Thread Starter
justdiff
justdiff's Avatar
Bumping this back up, check out all our different differential covers:
We carry covers from all the top manufacturers including Nitro, ARB, Riddler, Solid, Rockcrusher, Teraflex and many more. If you need a quote or have any questions let us know.
justdiff is offline
post #3 of 13 Old 04-03-2015, 04:40 AM Thread Starter
justdiff
justdiff's Avatar
Check out Jordan of JRT Offroad Racing taking his chase truck up Potato Salad Hill at EJS today. Jordan is running NITRO differential covers, Detroit lockers, and an assortment of other NITRO gear and axle products:
justdiff is offline
post #4 of 13 Old 07-02-2015, 05:06 AM Thread Starter
justdiff
justdiff's Avatar
We make differential covers for many different applications ranging from trail rigs to tow rigs and everything in between. Check them all out here:
justdiff is offline
post #5 of 13 Old 04-03-2016, 05:29 AM Thread Starter
justdiff
justdiff's Avatar
Made in the USA Nitro X-Treme Aluminum diff covers look great, help keep your axle cool and are extremely strong (proven in Ultra 4 racing applications). Nitro makes them for all common applications and we stock virtually all of them in both our warehouses.
Starting at just $139.99, check them out here.
You can find all the various differential covers we stock from different manufacturers here.
justdiff is offline
post #6 of 13 Old 06-16-2016, 05:57 PM Thread Starter
justdiff
justdiff's Avatar
Besides NITRO differential covers, we also stock a few other manufacturers covers. Including the ever popular and extremely durable nodular iron ARB differential covers. Check out all the ARB covers HERE.
justdiff is offline
post #7 of 13 Old 07-11-2016, 05:56 AM Thread Starter
justdiff
justdiff's Avatar
NITRO differentials covers and durable and lightweight, we stock all the popular models too! Click this link for pricing or call 866 349 6801 and speak with one of our Differential Experts to learn more!
justdiff is offline
post #8 of 13 Old 07-19-2016, 08:24 PM Thread Starter
justdiff
justdiff's Avatar
The first few of these new Nitro Alloy covers in red powdercoat have started shipping with a big batch in production shortly. Dana applications available to order now! Click here for details.
justdiff is offline
post #9 of 13 Old 10-24-2016, 09:52 PM Thread Starter
justdiff
justdiff's Avatar
Most oils today are 'Multigrade' oils, which means that the oil is defined by 2 viscosity grades (i.e. 10w-40, 5w-30, etc). Multigrades were developed more than 50 years ago to avoid the requirement of using thick oil in summer and thin oil in winter. The W stands for winter, not weight, which means that the oil has a certain viscosity/flow at low temperature. A lower 'W' number means the oil performs better in cold temperatures. The non 'W' number indicates the oil viscosity level at 100°C (212°F).This is a fixed limit, all oils that end in the same number (30) must meet the limits.
We recommend using 85w-140 in differentials. Whether you are changing out a differential cover, or just replacing the fluid, it's important to use the right oil in your diffs.
justdiff is offline
post #10 of 13 Old 01-04-2017, 11:52 PM Thread Starter
justdiff
justdiff's Avatar
Don't forget about a new differential cover when you're upgrading your gears or differential parts. They are cheap insurance against rocks and obstacles on the trail. You can check out all the differential covers we stock, HERE.
justdiff is offline
post #11 of 13 Old 04-19-2017, 04:08 AM Thread Starter
justdiff
justdiff's Avatar
Differential covers are always in stock! Whether you're rock crawling, towing heavy trailers, or building a street car; we have the covers to suit all your needs. Check out all the different ones by following the link below:
Differential Covers at JustDifferentials.com
justdiff is offline
post #12 of 13 Old 05-15-2017, 05:38 AM Thread Starter
justdiff
justdiff's Avatar
Check out the newest online issue of JPFreek Adventure Magazine and a full install article on their project LJ using Nitro Gear components, including aluminum differential covers!
justdiff is offline
post #13 of 13 Old 06-16-2017, 06:11 AM Thread Starter
justdiff
justdiff's Avatar
NITRO aluminum differential covers can help cool and protect your gears, while handling whatever you can throw at them. Check out all the NITRO cover differential covers we stock below:
justdiff is offline
