5.9L Years interchange? What will work for my '02 Durango - Dakota Durango Forum
5.2L/5.9L/6.7L Engines Questions regarding the 5.2L/5.9L/6.7L V8 Engines
post #1 of 10 Old 12-27-2011, 05:35 PM Thread Starter
BigTom209
Vehicle: 2002 Durango
I have a '02 Durango with the 5.9L motor that's no good so I'm on the hunt for a replacement motor. Looking at car-part.com it seems that 2002-2003 are the engines that directly swap into my Durango but I know from past experience often you can use other year motors it just might require swapping some sensors from the old motor to the new one.
So I'm curious, what years of Dodge can I use the 5.9L block in my '02 with fairly minimal effort? I found a '01 truck and a '99 Durango at the local wreckers both with 5.9L motors, but I don't know if they'll work.
Thanks
BigTom209 is offline
post #2 of 10 Old 12-27-2011, 08:01 PM
rangoRT
rangoRT's Avatar
Vehicle: 2000 Durango R/T
It's more than swapping sensors, in some cases you'll need the accompanying wire harness of the new engine, along with the PCM for it to run without issue. The problem you'll might run into is a rough running engine if you swap the block only, and you'll need to get it properly tuned with the old PCM. I'd stick with a newer block anyway unless you want to get a proper rebuild. I can't say for certain if the block from other years are direct replacement as throughout the years there have been changes to the vehicle as a whole, although I don't think it'll affect swapping the engines. A good local shop will know, or even a performance/tuner shop in the area.
2000 Durango R/T
136 000 miles
--SCT 87 Octane Tune--Mangaflow Cat Back--K&N FIPK (currently using Amsoil cone filter)--52mm Fastman TB--
rangoRT is offline
post #3 of 10 Old 01-10-2012, 08:18 PM
Misfit
We Are 138
Misfit's Avatar
Vehicle: 98 Dakota V6 & 03 Cobra
Modifications: CAI,Xhaust,Flux Capacitor
Quoted: 20 Post(s)
Garage
As far as I know, a 5.9 Mag is a 5.9 Mag whether it's a 96 or 03.
That being said, you're probably right, just swapping your sensors, etc. Small shit like that.
Misfit is offline
post #4 of 10 Old 01-10-2012, 08:30 PM
1999BLKDAKRT
Vehicle: 1999 DODGE DAKOTA R/T
Modifications: SHAKER HOOD, 51.5 BLKDAK TB. HEADERS, MOPAR PCM, 100 SHOT ZEX WET KIT.
It's 93-03 for the Magnum 5.9
1999BLKDAKRT is offline
post #5 of 10 Old 01-29-2012, 11:09 PM
OntarioRT
5 DOOR WHORE #250
OntarioRT's Avatar
Vehicle: 2003 Dodge Durango R/t
Any update on a clear answer for this? I have 156,000 on my D's motor and Iv been looking for a donar 5.9 to strip down and build up from scratch with some minor upgrades. Once done I want to drop it in and do the same to my factory motor. Iv been searching high and low. So far I have found a 2000 RT with a junk tranny for 800 bucks and a 2001 Ram 5.9l motor for 180.00. I dont know which to go with.
The Below beloved truck is sold, and I have blown up the motor on my SLT PLUS 4.7, currently no vehicle
** 2003 Durango R/T, Dark Garnet Red, One of 173 in 2003. **[20" RT Replicas on Falken Ziens 295/55, Infinity Refrence, Audiobahn 12", HID w/High beam 10000k bulb** 165,000km, Clear headlamp, 180T-stat, 14" Round Element K&N with Extreme lid, Accel Mopar Super Coil]
The build date for your vehicle was October 17, 2002. The build hour was 13 and the Colour Code is PRV- Dk. Garnet Red Pearl Coat.
OntarioRT is offline
post #6 of 10 Old 01-29-2012, 11:24 PM
AmberFireDaK
AmberFireDaK's Avatar
Vehicle: 2000 Dakota R/T
Quoted: 2 Post(s)
Send a message via MSN to AmberFireDaK
all magnum 360's are the same, like misfit said you might just have to swap your sensors onto the new engine, and keep your harness and PCM
- Justin
AmberFireDaK is offline
post #7 of 10 Old 01-30-2012, 01:27 AM
uwntsumrtII
White Trash
uwntsumrtII's Avatar
Vehicle: 00BWCC,00AFRC,00PBD R/T's
Send a message via AIM to uwntsumrtII
you'll be fine with any Magnum 360.
uwntsumrtII is offline
post #8 of 10 Old 03-14-2017, 08:47 PM
samsam413
the Crank sensor ring is different for 2002 and 2003..Tou have to use 2002 and 2003 only for a direct fit....
samsam413 is offline
post #9 of 10 Old 05-12-2017, 08:46 PM
mopar5.9
mopar5.9's Avatar
Vehicle: Durango SLT 1999 4X2
Modifications: Bolt ons
Quoted: 5 Post(s)
Garage
From what i know any 5.9 from 1993 to 2003 will fit . the block itself will fit just like the others says about some plugs are different . i have done a 5.2 to 5.9 swap with transmission swap . i used a 5.9 from 1997 out of a Ram for my durango 1999 and a 46re from a dakota rt 2000 .
The 5.9 from 97 has 235 HP while the 5.9 from 98/03 has 245 HP. it is pcm related . so the 5.9 from 1997 also has 245 hp in my 99 durango instead of 235hp
mopar5.9 is offline
post #10 of 10 Old 06-18-2017, 08:12 PM
Frankie87YJ
Automotive Neurosurgeon
Frankie87YJ's Avatar
Vehicle: 03 Dakota SXT
Modifications: 5.9L swap - otherwise, stock
That's awesome
Frankie87YJ is offline
