I'm still trying to sort out this problem of the center of my water pump pulley hitting my coolant reservoir (and wearing a hole in it) on my 2000 Durango.
The protruding center of my water pump pulley (the center female part that is pressed onto the male shaft of the water pump) is only about 1/4" away from my coolant reservoir. So it only has to move forward about 1/4" before it hits the coolant reservoir.
Is that unusual? Could that be the problem?
Is the center of the water pump pulley on your Durango farther away from the coolant reservoir than 1/4"?
Really the water pump pulley shouldnt be anywhere close to the coolant reservoir. Or do you still mean power steering pulley? Anyway you can take some pics and post them. Showing the gap, where it's rubbing and maybe a picture of how the reservoir is mounted to radiator.
Sorry, yes, the center of the power steering pump pulley (not the water pump pulley) is about 1/4" away from the coolant reservoir. It seems that the engine moves forward under braking or something and the center of the pulley hits the reservoir.
It's the 5.9 liter engine.
How far away from the reservoir is the center of the PS pump pulley in other 5.9 first-gen Durangos?
I'll see if I can post up some pics when I get to work.
It's been a long time since I've had the factory shroud on my truck, or paid much attention to one in person to say, but I think that may be a little close. Do you have a pic from further away and not such a close up?
I could take another one, so that I take the pic from the correct angle what are you looking for?
I could shoot a video too, if you like.
As far as my buddies and I can tell the shroud is mounted completely flush with its mounting brackets in the front, so it can't go any further forward.
I'd almost say it's got the wrong pulley on it.. That snout sticks out way farther than any I found pictures of in a quick search (mine is a 4.7, and the snout is flush with the front of the pulley as well).. There should be more clearance than that. But there's also no reason the drivetrain should be shifting forward that much..
It's been years since I've paid much attention to a factory 2000+ shroud and how close it is to the front of engine. I removed mine right after I bought the truck when I installed an E-fan. Pic from side showing the whole shroud and clearance with front of motor. Maybe where it mounts to the radiator to make sure the shroud isn't loose there.
I just looked at the new shroud I bought and it has a tab at the bottom that must slide into a slot on the top of the radiator to hold that skinny little leg in place.
I'll bet the genius (me) who replaced the busted rad a few months ago never saw that tab and never got it into the slot, or maybe even unknowingly busted it off.
If I don't post up again on this thread, that's what it was.
Thanks guys, I really appreciate your help!
Andy
Related Threads
Dakota Durango Forum
1.4M posts
50.4K members
Since 2003
