Are the interior door panels for a quad cab Dakota the same as a Durango? They appear to be but I know the a-pillar panels are not as the handles on the Durango are smaller.
FYI the panels are slightly different- I know the inserts are shorter as I tried to swap over a set of the leather Durango inserts onto my 00 Dakota door panels and it was a no-go.
The inserts are not the same size which means the panels are also not the same. Cant take and put a durango door on a dakota. Same goes for door panels.
If you tried to use panels from a Durango on a 2dr Dakota, then you are right the panels will be short. Thats because the regular cab and club cab Dakotas have longer doors than the (front doors) Quad cab and Durango. The OP wanted to see if quad cab panels were the same as Durango panels and they should be as those doors are the same.
Ed
Related Threads
Dakota Durango Forum
1.4M posts
50.4K members
Since 2003
