I bought this 2001 Quadcab 4WD to convert it over to a Cummins w/NV4500. But for now I have decided to just bring it back with a fresh rebuilt 4.7 with factory 45rfe.
The prior owner said there was a terrible knock in the engine. When I asked about the knock he said it sounded like the engine was going to come apart at anytime so he pulled the motor and then never did anything with it. I bought the truck for 900 dollars. The body is in decent shape, silver grey, with cloth interior. The only damage on the body is the hood which was picked up by the window and blown across the yard into a pole and dented up.
I broke down the engine and discovered the only thing wrong with it was a few of the center pistons had worn pistons skirts. That is what caused the piston slap due to to much wiggle room in those cylinders.
So here is what I have into the truck as of today.
900.00 2001 Quadcab 4WD
79.00 Complete FSM Set
engine:
300.00 4.7 Crank kit with warranty
500.00 Engine tanked, machined, rods balanced, etc....
670.00 Two Complete rebuilt heads with 3yr warranty
143.00 NPR Pistons and rings 0.5mm over
310.00 Felpro complete engine gasket kit with head bolts
110.00 Sealed Power Oil Pump
41.00 Bosch Waterpump
52.00 2X 9-5426 Timing Chain guides
27.00 Timing Chain tensioner 9-5423
40.00 Timing Chain tensoiners 2X 9-5427
18.00 NGK V Power Copper plugs X8
6.00 Bosch Oil Filter
9.00 Fram Air filter
27.00 Crankshaft Positioning Sensor
28.00 Camshaft Positioning Sensor
21.00 Coolant Temp Sensor
3291.00 Total
260.00 31x10.5x15LT New Studded and Sipped on Rims
3551.00 Total
