Trans Temp & O/D Off Lite on?????????? - Dakota Durango Forum
Transmissions Shift Kits, Transmissions, Torque Converters, Clutches
Thread Tools Rating: Thread Rating: 2 votes, 5.00 average. Display Modes
post #1 of 18 Old 06-09-2009, 01:13 AM Thread Starter
Harley
01 Durango R/T
Harley's Avatar
Vehicle: 2001,Dodge Durango R/T
Modifications: Bone Stock
Quoted: 0 Post(s)
I have a 01 Durango R/T and when I was driving home today, my O/D Off light came on and I could not switch it to off. Then a few miles later the trans temp light came on. Lucky I was only about a mile from the house and when I made it home, I checked the fluid and it is right on. The temp outside today is in the mid 90's. Not sure what the deal is. Any help would be great!!!
5 DOOR WHORE #194
Harley is offline
Sponsored Links
Advertisement
post #2 of 18 Old 06-11-2009, 09:49 PM
jweltch
People suck.
jweltch's Avatar
Vehicle: 03 Black CC Dakota R/T
Modifications: Interesting stuff
Quoted: 0 Post(s)
Your transmission overheated and went into limp mode. This takes it out of overdrive and (I think) locks the torque converter. It of course also turns on the "Trans temp" light on the dash.
Were you towing with it or something?
Another Jason! - Maricopa, AZ
2001 Red Durango R/T -His
2003 Black CC Dakota R/T -Hers
jweltch is offline
post #3 of 18 Old 06-11-2009, 10:03 PM
BPKOTA98
Fuck Obama!
BPKOTA98's Avatar
Vehicle: 98 Dakota RC SB V6
Quoted: 0 Post(s)
Quote:
The trans has a fault witch, cut off lock-up and made the tranny run hot, thats what cut the temp light on. I would scan the computer and see what codes you got.
BPKOTA98 is offline
post #4 of 18 Old 06-11-2009, 10:34 PM
jweltch
People suck.
jweltch's Avatar
Quoted: 0 Post(s)
What language was that? I don't even understand what that means.
Here's some real information... Scanned out of my 01 Durango Factory Service manual.
jweltch is offline
post #5 of 18 Old 06-12-2009, 12:19 AM
BPKOTA98
Fuck Obama!
BPKOTA98's Avatar
Quoted: 0 Post(s)
Hey you can be a smartass all you want but i work on these trucks everyday. Not just some guy who reads stuff on the internet. Just an FYI for ya the transmisson in that truck doesnt have a limp mode.
BPKOTA98 is offline
post #6 of 18 Old 06-12-2009, 12:23 AM
myrtlebeachbst
The red Beast
myrtlebeachbst's Avatar
Vehicle: 98 Durango SLT 5.2L
Quoted: 0 Post(s)
Hands on VS the Auto Manual, Hands on wins every time.
myrtlebeachbst is offline
post #7 of 18 Old 06-12-2009, 12:51 AM
jweltch
People suck.
jweltch's Avatar
Quoted: 0 Post(s)
Quote:
Alright. You work on these every day, then you must have a copy of the FSM handy, right? Check out page 21-316 of your 01 Durango manual (the same page I scanned in from my own copy) and tell me what you'd call that, if it's not a limp mode.
Just because you work on these every day doesn't make you smarter than a manual. I work on $250,000+ industrial machinery every day and I still don't quite have those electrical prints memorized just yet.
Also, for what it's worth... If you're going to try to help someone out, at least do it in a way that they can understand. Rolling your face across the keyboard while thinking about how to fix it doesn't count.
jweltch is offline
post #8 of 18 Old 06-12-2009, 01:15 AM
BPKOTA98
Fuck Obama!
BPKOTA98's Avatar
Quoted: 0 Post(s)
First, If you don't like what I have to say O WELL! You did not need to respond with anything about it. Second, that is still not limp mode. Limp mode in a chrysler puts you back to second gear. Also read his post it says that the o/d light was flashing before the trans temp light came on. So that would lead me to believe there is another problem. I don't work on 250,000+ industrial machinery, I work on transmissions like the very one he is refering to.
BPKOTA98 is offline
post #9 of 18 Old 06-13-2009, 07:11 AM
medic201
Toxic Avenger
Vehicle: 2003 Dodge Durango
Modifications: Magnaflow Debadged Tint
Quoted: 0 Post(s)
Garage
Ok this is exactly what mine is doing. The scanner is not picking up a error code but it does say the fluid temp is 266 at idle and the OD switch on the shifter is working but will not turn the light off. It did show a code of P1740 the first time it did it a month ago. Now it has been in and out of the shop 4 times. It works perfectly for about 30 miles then the OD light comes on, doesnt flash just stays on, it shifts into third and the trans temp light comes on. The governor solenoid, 4th gear and lock up solenoids have been replaced, the cooler and cooler lines have been flushed. The overdrive unit was pulled and inspected. It checked out ok and was put back in. The wiring loom was replaced. It wont shift into first in drive from a stop. It feels like it is stuck in second until it cools off. Im open to any suggestions at this point. Its a 2003 5.9 4x4 durango.
medic201 is offline
post #10 of 18 Old 06-13-2009, 02:48 PM
BPKOTA98
Fuck Obama!
BPKOTA98's Avatar
Quoted: 0 Post(s)
Quote:
I would like to know if they replaced the govenor solenoid, or did they just clean it. also did they replace the govenor pressure sensor(trans temp sensor)? I would be looking at the temp sensor. The P1740 is a TCC Solenoid performance code, one of the few possible causes for this code is a temp sensor problem. Also do you have a scan tool you can use to watch the govenor pressure while driving the truck?
BPKOTA98 is offline
post #11 of 18 Old 06-13-2009, 06:39 PM
medic201
Toxic Avenger
Quoted: 0 Post(s)
Garage
No I do not have a scanner. Im supposed to take it back today for round 5. Can the trans temp sensor fail with out throwing a code? They are thinking mechanical now because its not showing any fault codes.
medic201 is offline
post #12 of 18 Old 06-13-2009, 07:04 PM
xbxjunkie
the DOC can SUCK IT !!!
xbxjunkie's Avatar
Vehicle: 2012 Durango R/T
Quoted: 2 Post(s)
not saying this is it but i'll throw it out there, in one of the trans cooler lines there is a check valve built into it, something to do with the flow of the tranny fluid, perhaps when the lines were flushed maybe some crap messed it up somehow.
xbxjunkie is offline
post #13 of 18 Old 06-13-2009, 07:45 PM
medic201
Toxic Avenger
Quoted: 0 Post(s)
Garage
Quote:
Thanks, I am willing to check anything at this point.
medic201 is offline
post #14 of 18 Old 06-13-2009, 08:28 PM
BPKOTA98
Fuck Obama!
BPKOTA98's Avatar
Quoted: 0 Post(s)
If the temp sensor is reading the wrong temp it can cause alot of werid things to happen with out setting a code. Also check the govenor solenoid and make sure it was replaced. The transmission will not act right with junk in the soleniod.
BPKOTA98 is offline
post #15 of 18 Old 06-28-2009, 05:21 PM Thread Starter
Harley
01 Durango R/T
Harley's Avatar
Quoted: 0 Post(s)
I ended having the govenor solenoid and 4th gear and lock up solenoids replaced as well and now my trucks starts off in first gear and all was good for about week. Driving home the other day (12 miles) from work, my o/d off light came back on but the trans temp did not. Though when I went to work the next morning, everything is fine. It is only happening when I drive home and it is 100 degress outside. I took it to the shop again and they that the fluid will need to be changed or I might have a faulty o/d unit and quoted me around $600 to replace. Ouch. will update on what I decide to do, (sell or fix)
5 DOOR WHORE #194
Harley is offline
Sponsored Links
Advertisement
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
User Tag List
Linear Mode Linear Mode
You may post new threads
You may post replies
BB code is On
